Hydrolocking??
Old Mar 26, 2006 | 01:26 AM
chimael's Avatar
Hydrolocking??
What gaskets fail that lead to hydrolocking in the 4.2L? Intake plenum only?
Old Mar 27, 2006 | 05:34 PM
BlueOvalFitter's Avatar
The lower intake gaskets that seperate the lower intake from the heads.
Old Mar 28, 2006 | 01:37 PM
rick56r's Avatar
BlueOvalFitter: can this also be causing the ticking noise that i'm hearing in my truck, I'm getting the gaskets this weekend.
Old Mar 28, 2006 | 05:52 PM
Rick,your ticking noise can be one of many things; a stuck lifter,exhaust leak,the fuel injectors,etc.....
Are you replacing the gaskets yourself?
Old Mar 29, 2006 | 10:40 AM
rick56r's Avatar
Hydrolock;
Yes, and it dosen't look very bad on the 4.2, but I'd be kind of dreading it on the 4.6 or 5.4.
Old Mar 29, 2006 | 05:15 PM
STOMPTHECHEVY's Avatar
HEY UR ticking sound can Also be from a Cracked Spark PLUG!!
IF ur wire is burned or cracked, the current is gonna pass through it and make that noise. I would check all wires, just to make sure.
Old Mar 29, 2006 | 05:36 PM
Exclamation
Make sure you get the correct torque specs from Ford; the Haynes and Chiltons manuals are incorrect! Also,change the oil "before" cranking the engine! Excess coolant and gasket debris can find its way into your oil pan during the gasket replacement procedure! BTW,this would be a good time to clean the EGR ports and IMRC runners on the lower intake!
Old Mar 30, 2006 | 09:39 AM
rick56r's Avatar
Ticking Sound
I just replaced the plugs and the wires looked fine, also it was doing this before
I changed them.
Old Mar 30, 2006 | 09:40 AM
rick56r's Avatar
Ticking Sound
Thanks BlueOvalFitter, I apperciate the information.
Old Apr 2, 2006 | 10:07 AM
rick56r's Avatar
Peck;
BlueOvalFitter and STOMPTHECHEVY, thanks for the advice and information on my 97 f-150, I've replaced the intake gaskets upper and lower, and now the truck runs fine also it took care of my pecking I had in the motor! again guys thanks.
Old Apr 29, 2006 | 09:56 PM
fnsane's Avatar
Torque specs
So, what are the correct numbers? I'm fixing to do this.
fnsane
Old Apr 30, 2006 | 12:17 AM
Cool
fnsane
I cant remember but if you call your local Ford dealer they will give you a printout of the TSB on the lower intake gaskets revision.It gives you the torque specs along with special instructions on the revised gasket installation.
