'02 Intake Problems
Old May 20, 2005 | 03:16 PM
coachhop's Avatar
'02 Intake Problems
I own an '02 with 145000 miles on it. My check engine light came on. I took it to Ford, and they said I was getting a lean code on the passenger side. When they found the problem, they told me they thought it was an intake leak due to a failed gasket or cracked intake. (They found the leak by carb cleaner near the back of the intake and noticed a jump in the reading of the oxygen sensor.)
I picked up the truck and decided to save money and do the work myself.
When I tore the truck down, I noticed that there was a lot of thick grime around the intake ports of the lower intake manifold. Obviously, I had a leak that allowed dirt to be sucked down the intake.
1. Does this sound like a bigger problem than just intake gaskets?
2. Should I take off the alluminum intake manifold to look for more leaks?
3. Could any problems with the IMRC cause this problem?
4. Has anyone else seen this before?
Old May 31, 2005 | 01:10 AM
fordinlinesix's Avatar
Nope, sounds pretty normal.
I wouldn't bother with it, you would have to drain the antifreeze, might as well just leave it as it is.
No.
Yeah on a 4.0 OHV Explorer motor. A lot of times the bolts vibrate loose when they get some miles on them.
