what problems have you had?
there are 3 ways to fix heat sheilds all are cheap fixes. the best way is to get a big hose clamp or 2 and tighten them down real good on the heat sheilds. if the little tag in the heat sheild is rattling you can dig it out with a screw driver. and the last recomondation is to just remove the heat sheilds.
2002 F-150 30k Miles
Problems
Broken Seatbelt
Broken 02 sensors (2 times)
Power Driver window went out once
Rear window seal came off once
Running rich once
Left rear leaf spring (replaced 4 times)
Right rear leaf spring (replaced 3 times)
Truck has basically been &^$%, but I'm currently working with ford and the dsb to do something about it, hopefully they will purchase it back so I can get a new 05. Worse case senario I get an extended warranty and sell it down the line for a new 1. This has been my 4th ford, and the 1st one to have problems. I just got a lemon.
SDF150GUY
Problems
Broken Seatbelt
Running rich once
SDF150GUY
None yet Knock wood
I must of gotten a strange one? The only problem I have had sence new was the rear window seal was coming off from bad glue. It was fixed under warranty.
I have a 2002 xl v6 /5 speed with 68,000 and no problem at all. I plan on keeping it till 200,000 or more. Just did the oil and fluids changes.Still running on original tires.
More dependable then the Sushi Grinders.
Definatly more class and keep the dollar in the USA
Taylor - you should search in the brake froum regarding the ABS light. There is apparently a sensor (under $30 at Auto Zone) and an easy install that can cause the ABS light problem.
FWIW, there are disreputable repair shops out there that will prey upon your fears about safety. This is used all the time to sell unnecessary or overpriced brake repairs. 'Free Vehicle Inspections' are often used as a way to reel the suckers in for unnecessary brake work.
