Extra Engine noise when serpentine belt is on.
I have a 1989 F150 with the 300 engine. The engine suddenly started getting loud. Eventually, the serpentine belt jumped off. I noticed the noise went away with the belt off. I replaced the belt, and the noise returned.
With the belt off, I can grab the fan blades and move the blades back and forth toward and away from the engine. Is this a sign of a bad water pump?
thanks.
thanks.
If it's the water pump, careful, I've had those things seize up so bad, I couldn't start the vehicle...
Have you tried the old dowel trick? Take a broom handle/dowel and touch the suspected part, place the handle to your ear and you'll definately know when you hit the noise maker
