Oil for High Mileage
It should be ok to switch to synthetic up to about 75,000 miles. the reason they say not to change on an older engine is because the regular oil creates a carbon buildup around the piston rings, and thus creates a type of seal. If you replace it with synthetic, the synthetic will actually clean up all of that carbon and there will not be a seal, therefore causing it not to work properly. I switched to synthetic at 65,000, and I only have to change it every 10,000, works great. Also put synthetic in my rear diff and trans. Highly recommended by me.
The carbon buildup is like grit or sand and it will eat up the cyl. and rings. On high milage engines, 100,000 +, the crud can be cleaned out of the engine by use AutoRx for 1500 miles. Then safely switch to a syn. Under a 100,000 switch when ever u want to unless u have a really drity engine.
willb
willb
