300 to 351w swap?
300 to 351w swap?
I have an 84 F150 4 speed manual 4x4 and the motor is knocking and not holding good oil pressure when hot (prob cam bearings). I am considering a 351w swap. Will the driveline components bolt up and hold? I assume i'll probably have to swap the clutch but other than that.....transfer case.....transmission. Also...what will need to be changed besides motor mounts and possibly exhaust.
Thanx for helping the new guy
Joe
Joe
get a 28 oz flywheel for a truck , 351 w motor mounts and matching v-8 frame mounts and you should be fine . Radiator is different " i think the hoses are backward" and you will need to re-do the exhaust but yes everything will hold up fine and will fit your truck .
shoot me an email if you have any other questions .
