Hurst 5 speed shifter
Old Oct 5, 2003 | 01:44 AM
Ava's Avatar
Ava
Question Hurst 5 speed shifter
Anyone out there have a the new Hurst shifter on thier 5 speed tranny yet? I'm going to buy one but I just thought I would see if someone already has one and how do you like it? Mark M
Old Oct 6, 2003 | 07:55 PM
RB/CT's Avatar
Thumbs up
Just thanking you for the info. I have a 98 F150 five speed and have been waiting for Hurst to come out with a shifter. They have had one for the Chevrolets for quite a while. Now if they make a nostalgia type ball with the shift pattern it would be great. (similiar to the Camaro one, white or black ball)
Old Oct 9, 2003 | 03:13 AM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
Is there a part number for it . I can't find one on there web site?? all they have is for the 5.0 thru 96
Old Oct 10, 2003 | 12:23 AM
dave186's Avatar
I have the one for the 5.0, and it has the black ball with the white pattern on it.
Old Oct 10, 2003 | 11:03 PM
Quick4.2L's Avatar
hey guys. dont get too happy with this, because to be honest, it exists but its not being sold. there were problems with the design of some of the cabs on our trucks that they had shifters hitting the dash and stuff like that. if you want to see one go to www.troyerperformance.com and go to transmissions and to go 5speed. you will find it there. they have a price and everything but i doubt they would sell it. but check it out for yourselfs. its always good to wish.
Old Oct 19, 2003 | 01:56 PM
exfordguy's Avatar
Angry Hurst 5-speed shifter
I ordered one from Troyerperformance. The next day I got a reply from them saying the shifter is still in R&D and won't actually be out until November. The reply was from Mike Troyer's wife (I'm embarrassed that I can't remember HER name). I think they should put some type of statement on their site saying the shifter isn't available yet. Once it is available and the"bugs" have been worked out I definitely plan on buying one. The stock shifter in my truck is kind of "finicky" and has problems shifting 1 - 2. The same thing happened with my '97 (I have a "00 now). Anyone else have this problem?
Old Oct 20, 2003 | 08:32 PM
Ava's Avatar
Ava
Well when they get it right, I'll be buying one also! Mark M
Old Oct 26, 2003 | 01:49 PM
El Matto's Avatar
yeah... i have a problem going from 1rst to 2nd in my '98... i also have a really hard time getting it into reverse, it grinds most of the time.
Old Oct 26, 2003 | 09:03 PM
Scott D's Avatar
Grinding when going into first or reverse from a stop can often be clutch "dragging" due to a clutch problem. Maybe even something as simple as flushing & bleeding your clutch.
Scott D
Old Oct 26, 2003 | 10:08 PM
El Matto's Avatar
you mean it could be fixed by something as simple as flushing and bleeding your clutch?
Old Oct 27, 2003 | 12:01 AM
Scott D's Avatar
It is possible. Becuase it is grinding going into reverse from a standstill, I would definately try to rule out a clutch problem before getting into the tranny.
You could have old contaminated fluid ( if its not been changed regularly), air and/or water, or a leaking cylinder.
Be sure to run a pint or two of new fluid through it to clear everything out. I use a Gunsons Eezi-Bleed which makes one-man bleeding a snap.
http://www.automotive-tools-parts.co...eeder_Kit.html
Could also be a damaged clutch plate causing dragging.
Post us with what you find..............
Scott D
Old Oct 27, 2003 | 09:01 PM
El Matto's Avatar
it doesn't do it all the time... i just went out there and started it up and threw it into reverse, no problem... but other times it doesn't, i think i noticed a pattern at one point... like it would only grind if i had already moved forward a bitand then stopped and switched it into reverse, but i'm not sure...
