power lock problem
Old Jan 21, 2003 | 12:37 PM
black98xlt's Avatar
power lock problem
This morning my power door lock did not work. The power unlock works fine. Has anyone seen or heard of this being a problem. It is quite cold today in New England and thus maybe a broken wire. I would like to think not. Is there a fuse that controls this. Again I think not.
Any suggestions would be helpful.
Thanks is advance,
Old Jan 21, 2003 | 02:04 PM
flafonman's Avatar
Could you describe the problem in a little more detail?
For example: Driver's door switch will lock/unlock pass door only.
If that's the case it could be a bad actuator in drivers door, or crimped wire.
If passenger switch operates both locks, but driver's doesn't it could be a bad switch in driver's door.
The system is served by a 15A fuse in position 3.
Old Jan 22, 2003 | 08:40 AM
black98xlt's Avatar
update to problem
Must have been a stuck actuator. I pressed on the unlock a few times and then back to the lock direction and it seems to have freed it up. It happened a couple of times so I might still need to do some maintenance to it at some time.
The original problem was that when I went to use the lock position on either door it would not do anything. The unlock side worked fine from either door.
Thanks for your help
Old Jan 22, 2003 | 08:49 AM
2Trucks1Wife's Avatar
Come on guys...lets keep questions in this forum related to 6 cyl engines
