Replacing 4.2 engine
Old Jan 20, 2003 | 11:40 AM
marivera's Avatar
Angry Replacing 4.2 engine
I need help. I am replacing the 4.2 engine in my 97 F150, I threw out a rod and when I contact engine rebuilders to get a rebuilt engine, they ask me if my engine, inside the oil pan has 6 or eight nuts holding some kind of plate. Unfortunately without almost pulling the engine, i cannot remove the oil pan, any suggestions as to what they are talking about. My truck is a 97 F150 two wheel drive, standard 5 speed shift.
thanks for any help.
Old Jan 20, 2003 | 01:08 PM
BoostedOne's Avatar
Ask them if they are sure they are talking about the 4.2V6 The 4.6L V8 has 2 different crank shaft patterns, one which takes a 6 bolt flywheel/flex plate, the other which takes 8 bolt flywheel/flex plate.
Maybe they are just mistaken on what you both are talking about, or he is confused which engine has the different patterns.
Old Jan 20, 2003 | 03:58 PM
marivera's Avatar
Replacing 4.2 engine.
Thanks for getting back to me BoostedOne, I called back and they told me that there are some studs that fit a plate underneith the pan, but they told not to worry ether one fits. Do you know the new torqe values for the intake bolts? Reading the posts here, indicate that Ford changed them from the original.
thanks
Old Jan 20, 2003 | 05:04 PM
BoostedOne's Avatar
Seethe other thread...
Old Jan 26, 2003 | 09:48 AM
superfreak's Avatar
hey they are talking about a stock windage tray, main stud girdle. it goes on the main cap studs and tightens up the main caps as well as providing some windage effect. you vin number should contain what engine it is, i think there is a romeo plant engine and a windsor plant engine.
Old Jan 26, 2003 | 01:13 PM
AjRagno's Avatar
Originally posted by superfreak
..... i think there is a romeo plant engine and a windsor plant engine.
I don't know about the windage tray but, all of the 4.2Ls are built at the Essex Assembly plant in Windsor, Ontario. The 4.6Ls are built at both the Windsor and Romeo plants.
Old Jan 27, 2003 | 12:55 PM
Max Rivera's Avatar
New torqe values
Boostedone, can you repost your post concerning the new torqe values again. I cant seem to find the thread, where you wrote about this.
