Mercon vs. Mercon V
Old Feb 18, 2022 | 12:03 PM
Mike.G's Avatar
Originally Posted by busejag
Thanks you guys for the info...basically here is what I have researched. Mercon/Dexron III is basically the same as Mercon V. The only difference is that Mercon V has more anti-shudder additive to cope with the newer trannies. So putting Mercon only to a tranny that calls for Mercon V may cause shudders. But putting the more slipperier Mercon V to an older tranny may cause slippage. Although my tranny has been running normal so far, I am draining it completely so as not to take any chances. Ford Philippines only gives us 2 years warranty and mine just ran out a few weeks ago! What is a good synthetic Mercon V? Thanks again...
Different types of transmission fluid but the same types of transmission solenoids.
Old Feb 18, 2022 | 06:16 PM
You replied to a 21 year old post.
Old Feb 26, 2022 | 10:17 PM
i was gonna say the same thing. Holy 21YR old thread resurrection
Old Feb 26, 2022 | 11:19 PM
JackandJanet's Avatar
Old threads never die. They don't even fade away!
- Jack
Old Feb 28, 2022 | 05:03 PM
BillSF9c's Avatar
Yes, and what a coincidence, same age as my 2001 ! Sorta stands to reason that some posts of the vast history of our tenth gens, would be as old. 😁
Mercon V is a bit convoluted in history too, and it's v difficult to learn... sorta like DOT 5.0 synth brake fluid is INcomptible but 5.1 IS compatible. O'Reillys hears from Ford to use AT. But my money is on a Real Pro, Darrin of BCAtransmissions. He warns against AT, in tenth gens at least, (maybe all older gens...?) as it is thinner. He says longevity will suffer. So, you listen to a corporation or to a Master.
Old Feb 28, 2022 | 06:19 PM
What exactly are you referring to when you say "AT"?
Old Feb 28, 2022 | 09:55 PM
BillSF9c's Avatar
Automotive Transmission Fluid... in common and general terms, versus a specific fluid such as old MerconV or the newer more compatible MerconV. I know very little of the minutiae. I'll do what Darrin says.
Old Feb 28, 2022 | 10:41 PM
"Universal" fluid should be fine as long as it meets Mercon V specs. Note that newer transmissions spec Mercon LV (6R80) or Mercon ULV (10R80).
Old Mar 1, 2022 | 01:49 AM
BillSF9c's Avatar
Apparently so... but I thought we were discussing 10th gen, which prefers Mercon. My apologies.
