Question for GAH or ? Tranny temp guage install
Hi Need some input. Havent installed one before but think i can. If i pay attention! HA Now its my turn to do it. So....
99SC 4.6l AT 4X4 4R70W. Has factory AT cooler, approx. 5"high X 10"long X 2" deep. Stacked plate design total of 9 plates counting top & bottom. Sure looks small? Yes, i saw NEAL HP posts. Got me to thinkin.
GAH-read old post 4-21-01 You installed mechanical guage-manifold-sender. (BTW-nice home page)
Read installs on both type guages. Hey guys, nice locations & installs in dash, consoles etc.
Whats the difference between the mechanical & elect. guage?
Is a manifold needed regardless of type of guage?
Elect.guage requires 12V to operate? Mech. dosent? As you can tell this is new to me.
One post said screwed sender into tranny. Another install in pan. GAH installed in line from tranny to radiator.
Interesting different installs, but leaves me a bit confused?
Need to get guage in, appreciate replies.
Live in Sparks, close to Summit Racing. Have their catalog, so probably will go there. Hope it comes with instructions?
Have a good one. OT
Have a good one. OT
Hi Old Timer,
I'll try to help you out as best I can.
A mechanical temperature gauge uses a copper tube full of argon gas with a "bulb" on the sender end that is inserted into the fluid that you want to monitor. As the fluid heats up, the argon expands and the gauge needle moves. An electrical gauge uses the change in resistance between the sender and ground to move the needle via a simple circuit. The mechanical gauge is more accurate, more durable, requires only two wires for illumination (if desired) but is less "adaptable" in terms of placement due to the copper tube - i.e. you can't shorten or lengthen the tube easily. The mechanical gauge will continue to give fluid temp with the engine off and the key out of the ignition.
A manifold is needed if you want to measure the fluid at the lines going to, or coming from the trans.
A mechanical gauge only needs a 12v and ground if you want to illuminate the face. Electrical gauges typically need 4 or five wires.
I copied Neal’s install because I wanted to "see" the maximum trans temps, not the bulk temps that you get in the pan. I installed the sender into the hard line going to the radiator. Last week I hit 220F climbing 1500' in 1.8 miles. I'm going to install a Perma Cool cooler with fan.
Hope this helps.
'00 5.4L AUTO 4X4 Lariat (Black/Silver)
'95 Thunderbird SC
'02 F-350 PSD CC DRW 6SPD 4X4 Lariat (order this year)
www.hawthorn-engineering.com
<font face="Verdana, Arial" size="2">What’s the difference between the mechanical & elect. guage?</font>
<font face="Verdana, Arial" size="2">Is a manifold needed regardless of type of guage?</font>
<font face="Verdana, Arial" size="2">Elect.guage requires 12V to operate? Mech. doesn’t? As you can tell this is new to me.</font>
<font face="Verdana, Arial" size="2">One post said screwed sender into tranny. Another install in pan. GAH installed in line from tranny to radiator.
Interesting different installs, but leaves me a bit confused?</font>
Hope this helps.
'95 Thunderbird SC
Hi GAH
Thanks for info. Seems logical the way you installed your tranny guage. You said you put manifold about 12" away from tranny, if i remember right, guess i have to figure out how much tube i need.
Do you know if it comes in various lengths pre-cut, Im not exactly sure where ill mount, but going to cutout in dash maybe more difficult than perhaps a lower area? I can see where you wouldnt want to kink the tube,& bending for the various angles maybe difficult.
I see your point on the mech.guage. Think i might go this way. Assume Summit will have the manifold, they only list guage & sender.
I assume there are compression fittings or? that adapt hard line to manifold. Saw pic you posted, so at least i know what to look for. Ill have to figure out size of hard lines.
Yeah, might be changing my factory at cooler, but first need guage, then i can see temps and go from there. Will be towing my TT next month, so gotta get with it.
If you make the upgrade to Permacool, hope youll post results. Did catch my attention.
Thanks again. Good luck. OT
<font face="Verdana, Arial" size="2">You said you put manifold about 12" away from tranny, if i remember right, guess i have to figure out how much tube i need.</font>
<font face="Verdana, Arial" size="2">Im not exactly sure where ill mount, but going to cutout in dash maybe more difficult than perhaps a lower area? I can see where you wouldnt want to kink the tube,& bending for the various angles maybe difficult.</font>
<font face="Verdana, Arial" size="2">Assume Summit will have the manifold, they only list guage & sender.</font>
<font face="Verdana, Arial" size="2">I assume there are compression fittings or? that adapt hard line to manifold. Saw pic you posted, so at least i know what to look for. Ill have to figure out size of hard lines.</font>
<font face="Verdana, Arial" size="2">If you make the upgrade to Permacool, hope youll post results.</font>
Hope this helps.
'95 Thunderbird SC
