Draining the torque converter
Old May 22, 2001 | 10:03 PM
Ford4ever's Avatar
Post Draining the torque converter
To drain the torque converter on a '92 f-150 do you remove the rubber plug and drain it through that hole or do you need to remove that entire metal plate behind the converter?
Old May 22, 2001 | 11:01 PM
Nomopar4me's Avatar
Post
rubber plug. roll the engine over till the drain plug is in sight. DO not overtorque the plug when you put it back!
