Transmission oil change
Old Feb 17, 2001 | 10:21 AM
N. Narvais's Avatar
Question
I was wondering if there is a certain brand of filter for transmission that is best? The shop I use on carries Purolator, would that be adaquate and how often do you change transmission fluid?
Will watch for replies..
1997 F-150 4x4- 4.6L w/5sp manual trans.
K&N air and oil filter Mobil 1 5w-30
15.5 to 17 mpg
Old Feb 17, 2001 | 05:53 PM
max mitchell's Avatar
Question
N.Narvais- The manual trans has a filter???
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Mobil 1, K&N oil filter.
Old Feb 18, 2001 | 08:26 AM
Mark Kovalsky's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by max mitchell:
</font>
No, the manual transmission does not have a filter.
Mark
Old Feb 18, 2001 | 07:54 PM
Wink
Mark-Thanks for clearing that up for N.Narvais; I was just kidding him !!
Old Feb 20, 2001 | 01:15 AM
N. Narvais's Avatar
Smile
Thanks for the info. The shop I went to said that I had to pick one before they could get started. I had not seen one in the Hayes manual I had read so I did not know.
I am glad this site is here so newbies (those who do not know anything) can get correct and accurate info.
You think the Shop would have given me my "old" filter to show how dirty it was??
Thanks again....I am learning.
Old Feb 23, 2001 | 05:30 PM
rockycarl's Avatar
Post
Just as info:
Purolator is the same as motorcraft. They manufacture all the filters for Ford. I know this because the trucking company I drive for ships motorcraft filters to the warehouse that supplies local dealerships with parts, and the shipper on all oil, air, and other filters is Purolator.
