Neal - Additional Cooler
Old Jan 24, 2001 | 05:57 PM
djbogue's Avatar
Post Neal - Additional Cooler
Neal or anyone, I have been corresponding with Mike from Superchips and he suggested that I talk to you about how you installed an additional transmission cooler besides the factory one. Can you tell me where you installed it, how, and any other information you can give me? I noticed that you installed a 14"/10" Perma Cool with 10" electric fan.
Thanks,
Dennis
Old Jan 25, 2001 | 01:10 AM
Neal's Avatar
Cool
HI!... DJBOGUE : Yes, I installed a PERMA-COOL 10.5 X 14 inch 5/8THED tubed tranny cooler. PART #PRM-3311. I also installed a SUMMIT RACING 10 INCH electric fan to that tranny cooler. PART #SUM-G4910.I removed the factory "STACKED PLATE" cooler. It was too small for my tastes and was mounted directly behind the front bumper on my truck. No air flow got to it so it was pretty much useless. I mounted my PERMA-COOL cooler directly in front of the condenser, right behind the grill on the driver's side. I used two brakets that I had left over from another project to mount the cooler. I bolted the brackets to the cooler using the holes provided and used stainless steel bolts, washers and poly nuts. I then screwed the brackets to the sheet metal frame that runs from the P,S to D,S underneeth the underhood plastic cowl. I then fabricated a 1 inch wide aluminum bracket that runs from the bottom of the cooler to one of the bolts that also holds the power steering cooler on. I wired the electric fan to a manual switch mounted in my AUTOMETER guage pod which houses my tranny temp guage. All tranny lines running from the tranny to the coolers are all AN-6 stainless steel braided with RUSSELL fittings. In the SPRING I am also going to be installing a similar cooler as a engine oil cooler on the passenger side, opposite of the tranny cooler. There will be NO fan on this cooler. This will be done with a OIL SANDWICH ADAPTER from SUMMIT RACING PART #TRD-1313. All oil cooler lines will also be AN-6 SS braided with RUSSELL fittings. Hope this helps you out.
NEAL " THE H.P FREAK"
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 330H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
Old Jan 25, 2001 | 05:13 PM
djbogue's Avatar
Post
Thanks Neal, it does help. Did you drain the trans fluid before changing the cooler?
Dennis
Old Jan 25, 2001 | 10:45 PM
Neal's Avatar
Cool
HI!... DJBOGUE : You don't have to, but I would while your at it. I had to because I installed my BAUMANN ENGINEERING shift kit at the same time. If you decide to change your tranny fluid, then don't forget to drain your torque converter also. Make sure you splice youe AUX tranny cooler in AFTER the lines coming from the factory one built into the radiator. If you decide to use a tranny temp guage, then make sure you install the MECHANICAL sensor in the lines before it goes into ANY of the coolers. Hope this helps you out.
