E40D Leak
Old Nov 22, 1999 | 08:17 PM
tonka toy's Avatar
Red face E40D Leak
okay...my first time to post here, but i've been reading for quite sometime, so here goes:
changed the transmission fluid a couple of weeks ago, dropped the pan, drained the TC, replaced the filter, put it all back together, put in a B&M drain kit to make it a less messy job next time and poured in $100 worth of mobil 1 ATF. on the test drive i was immediately stunned that a fluid change could make this much difference. shifts are much smarter and smoother. before on shifts under hard hard acceleration i sometimes thought i was going to loose the rear end...especially if i backed off just before it was about to shift...after the fluid change shifting is flawless.
now the problem...it leaks fluid, after 500 miles or so, it is still leaking out of the black grommet at the bottom of the bell housing. just enough to be aggravating, not enough to stain the garage floor (yet). my obvious first though was the TC drain plug that i had removed and replaced...no go, the plug is dry as can be, as a matter of fact the TC itself is dry...no evidence it is spinning fluid.
now the question...has anyone experienced this? any ideas where it is coming from? how did a simple fluid change cause it to start leaking. what is the fix...i hate the thought of dropping the transmission over a small leak, but the annoyance continues to build.
1997 F150 4x4 SC XLT
Styleside 5.4 ORP
BFG AT
Old Nov 22, 1999 | 08:42 PM
dirt bike dave's Avatar
Post
Is there any chance you may have overfilled the transmission? Good luck trying to stop the leak.
Old Nov 22, 1999 | 08:58 PM
tonka toy's Avatar
Post
thanks for the reply dirt bike...unfortunately it is not overfilled, it is right in the middle of the slash marks, i put in EXACTLY what came out...14.5 qts out, 14.5 qts in. owners manual says 16.4 qt capacity, so a couple of quarts in the cooler/lines seems reasonable to me.
Old Nov 23, 1999 | 08:59 AM
cphilip's Avatar
Post
Is it possible that during the refilling you spilled a little onto something and it is slowly dripping off? If the fluid on the dip stick mark ain't movin..... Maybe? If so it should clear up eventually huh?
97 F-150 SC Lariat, Styleside, White over Gold, 4.6L (Windsor), Automatic, 3.55 rear end, electronic 4X4, w/ every option of Lariat and ORP packages except the 17" wheels and the 4X4 decals, MODs so far: K&N air box mod, Gibson Super Truck, clear Bugflector II, Leer TSC 600 hard cover, Bridgestone Dueler OWL ATP 265/75 R-16's, TrailMaster Invader N7 shocks, Smittybilt step bars, Ford moulded mud guards, "White-white" head lamps, Bosch platinum + 4's.
