can I put in a different transmission
Is there any other manual transmission that I can swap in, I want to add more power to my 4.6 but don't want to kill my current trannsmission. Got a list of mods to do, most improvemnet is a set a aluminum or iron heads with better flow (any suggestions?) Or could the current tranny handle power increase from aftermarket heads. I gave up on the S/C though. Or is their any talk of centerforce or anyone else making better clutches?
Sorry for all the questions but I just got my truck and I'm to excited.
black 97' x-cab 4x4, 5 speed 4.6, completely stock for now
I don't know how strong the stock 5 speed is, but there are a couple of options. You could install a 5 speed from a Super Duty 5.4 engine which is strong but not a fast shifter. Or you could install a 5 speed from a Mustang GT. Either one would be a MAJOR project because even tho they will both bolt right up to your engine, getting the clutch linkage to work and possible shifter location changes figured out would be a real challenge. Personally, I think they should put the Mustang trans in at the factory instead of the Mazda trans.
'93 Regular Cab XLT Shortbed, 5.0, K&N, Borla, 160,000 miles; Future Expedition owner.
I don't think the mustang transmission would be compatible with the 4x4 transfer case wtihout a lot of work. The SD tranny would be the logical choice,but even so it may require a lot of work also,as far as transfer case, crossmember,etc.
Paul
Paul
Sorry, I missed the 4x4 part of your post.
With 4 wheel drive, all bets are off. Probably neither trans will work because I'm sure the transfer case is different on the Super Duty.
Hey, I'm in the same position. My low HP 4.6 is aready making my trany squeal on exceleration. I changed the trany oil(and all others oils) to Amsoil and the noise was cut out 90%. I originally wanted the 5.4, but Ford does not make it with a stick (5sp). So had to get the 4.6.... That right there tell you Ford knows the trany can't take higher power! I am trying to find out if the transfer case will fit the HD-trany. But - my clutch is also weak. It is on the verge of slipping. Thinking of going to the Mustangs SVT clutch. So much to do, but man, IT & I NEED IT.
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
97 - 4.6 - 5sp - 4x4 - stock - Flareside
Something to consider- On the Stangnet, guys are posting the Mustang still has the cable and quadrant. My 4.6 5-sp is hydraulic. As I remember, the '93
T-5 had a hydraulic clutch. Maybe that's what you are looking for.
I am in the same boat, but I will make no tranny changes until ESP expires.
As far as the shifter goes, if it doesn't fit, you can always elongate the hole, and build a new boot console.
'98 4.6 5-sp F-150
We've come for your Tundra.
http://www.mcmullenargus.com/gallery...ge=1165&pub=12
trixters-playground@excite.com
www.truckinweb.com
[This message has been edited by crash1 (edited 11-10-1999).]
'98 4.6 5-sp F-150
www.truckinweb.com
