Changing Tranny Fluid
Old Oct 27, 1999 | 09:47 PM
ZRracer's Avatar
Question Changing Tranny Fluid
Since I've never done this before I thought I'd ask all the experts that are on this site. Would I be able to change the Transmission Fluid in my truck myself and if so, how do I do it? Thanks, -ZRracer
98' F-150, Off Road, Short Box, Blue, 4.6, K&N, Auto, Captain Chairs, Dual Exhaust
Alpine CD Player, (2) 10" Rockford Fosgate Subwoofers and a big ol' Arctic Cat
sticker on the rear sliding window!!!!! Soon to be chipped!!!
Old Oct 28, 1999 | 11:02 AM
T Ellenberger's Avatar
Post
Yes, you can change the tranny fluid yourself. But, it can be a messy job. I installed a TransGo shift kit and I used one of those black rubberized pans to mix concrete/mortar to catch the old fluid. Also, there is a small rubber boot at the bottom of the bell houseing. Pull that boot and turn the engine until you see the plug in the torque converter. You can drain the torque converter and tranny by pulling this little plug. The service manual says not to reuse that torque converter plug so try to buy a new one from your dealer before you start. My dealer parts department didn't know it was there so I did not get a new one. You will also need a new filter. The pan gasket is reuseable so treat it wit a little care.
When refilling pour in 4 to 5 quarts, start the engine and let it idle and continue to add fluid until you get a full reading. Shift through all of the gears slowly before you drive it. After you are satisfied that it is full drive it and check one last time.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, 4.6, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs
