Transmission shudder!!
Old Aug 1, 1999 | 10:53 AM
jedison's Avatar
Post Transmission shudder!!
I have a 1993 F150 xlt,4x4,5.8L,E4OD and have been experiencing a slight shudder when starting in 1st gear and towing a travel trailer. No shudder when not towing! Any comments?
[This message has been edited by jedison (edited 08-01-1999).]
Old Aug 1, 1999 | 11:55 AM
scroker974x246's Avatar
Post
I had this same problem with my 92' Explorer 5 spd. The clutches that Ford uses in there vehicles are not great for towing. If you check the towing ratings for Ford manual trannys, they are about half of the automatics.
Old Aug 2, 1999 | 11:37 AM
nomo's Avatar
Post
While this site is terrific and has a lot of good info & people, it's primary focus is '97 and later trucks. You might find a few more opinions on the 80-96 mailing list at www.ford-trucks.com.
According to some of the guys there, the E4OD has/had a few problems. Since I don't have one, I never really paid that much attention to the posts, but there have been a lot of recommendations for improving the reliability of that tranny.
Neal
1997 4x4 Expedition- 4.6L, true dual exhaust w/glass-packs, K&N air filter, SuperChip, airbox mods, Edelbrock shocks, 285/75R16 BFG ATs, Optima "T-Bone" wheels, and Clarion In-dash CD player.
1993 4x2 F150 Reg. Cab LWB- 5.0L, cat-back dual exhaust w/glass-packs, K&N air filter, Superchip, fresh paint, and Line-X bedliner.
http://<a href="http://members.visua...s.com/NoMo</a>
Old Aug 13, 1999 | 12:14 AM
wschubbe's Avatar
Post
Jedison:
Do you have a limited slip differential? I had the same problem and it turned out to be the clutches in the rear end. Just get some friction modifier (if you have the LS rear end) from the ford dealer and drain some oil out of the rear end and add the friction modifier.
Old Aug 18, 1999 | 04:13 PM
LarryS's Avatar
Post
I have had this in almost every vehicle I have towed. It is caused by the trailer moving. Not a problem.
Old Aug 19, 1999 | 04:02 PM
Dennis's Avatar
Post
Jedison,
Check your tranny fluid. You may need to flush the tranny. If the problem goes away, don't worry about it until it returns. If the flush doesn't fix it, get a tranny expert to take a look at it right away.
