Transmission ratios
Old Jul 13, 1999 | 04:07 PM
LarryS's Avatar
Post Transmission ratios
Does anyone know the transmission ratios with a 97 4.6 F150 automatic with overdrive?
I have a 3.08 diffrential gear but need to determine if OD is too tall for towing 4000 lbs. This truck has no tachometer but I feel the rpm needs to be around 2000 at 60 mph to tow this much weight.
97 4.6 F150, 88 5.0 Mustang 1/8 = 7.409 @ 93.72 mph
Old Jul 13, 1999 | 06:38 PM
StrangeRanger's Avatar
Post
4R70W ratios:
1st 2.84:1
2nd 1.55:1
3rd 1:1
4th 0.7:1
at 60 in 4th you're turning 1300-1400 rpm,
3rd will put you a lot closer to the torque curve of the engine
Old Jul 13, 1999 | 11:49 PM
LarryS's Avatar
Post
Thanks StrangeRanger,
That .7 was what I was looking for. I just couldn't believe nobody knew this ratio. I bought my F150 used at a Dodge dealer so I could not get that information before I bought it. This kind of information is what I insist on before I purchase a new vehicle. Doesn't everybody?
Does look like I will be in D for pulling my Mustang. That puts me right at 2200 rpm at 60 mph. My tire diameter is 28" as close as I can measure.
