Performance Kit for a manual trans?
Old Jul 11, 1999 | 09:47 AM
fordfan's Avatar
Red face Performance Kit for a manual trans?
Does anyone know if there are any companies that have performance products for manual tranny's? I've looked at B&M but they seem to focus on automatics. Thanks
1989 F-150 XLT LARIAT 4x4 4.9L I6 5 speed manual tranny 3.55 gears K&N FIPK 3" Flowmaster.I will soon add a 4" lift and 33"tires and other mods too numerous to put here.
Old Jul 11, 1999 | 01:30 PM
T Ellenberger's Avatar
Post
What is it you wanted the performance kit to do? Try Hurst as they may have a replacement shifter that will shorten the throws between shifts. Any gear changes would get expensive.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, 4.6, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs
Old Jul 11, 1999 | 10:10 PM
Darin's Avatar
Exclamation
I don't think anyone makes a replacement shifter for the F150 5-speed. Replacing your stock tranny fluid with some synthetic ATF (redline) is about the only thing you can do.
