Transmission down shifts randomly
Old Mar 5, 2023 | 12:43 AM
Aaron Walls's Avatar
Recently had my transmission overhauled and with the exception of this one issue shifts and drives perfect. The transmission will sometimes not shift into 3 or it will randomly begin down shifting. I can seemingly make it shift by shifting to 2nd or bumping shifter towards neutral. I have changed filter and fluid as well as the plastic bushings in the column and screws that were loose on the column. Has anyone have any ideas? The truck is a 2002 F150 Supercrew with a 4.6
Old Mar 5, 2023 | 10:16 AM
Do you have a warranty on the rebuild?
Old Mar 5, 2023 | 01:42 PM
No warranty has expired the truck doesn’t have a lot of miles on the transmission. We started driving something else shortly after having the transmission overhauled.
Old Mar 5, 2023 | 07:20 PM
Mark Kovalsky's Avatar
The first step to fix this is to read the codes. Get Forscan at www.forscan.org.
Old Mar 9, 2023 | 09:24 PM
No codes
