transmission service
need advice .....
2008 F 150 FX4 with 93K miles - my driving is 75% city
last time I flushed the transmission(dealership) was 5 yrs ago with 67K miles.....
should I have it flushed again or drop the pan for the first time and change it that way ?
thanks
thanks
It might be worth looking at picking up a mity vac. I have had one for a few years now and have used it on my vehicles and it makes the transmission fluid change and absolute breeze on these trucks.
You just suck the fluid out the dip stick, Then measure what you took out and refill with the funnel through the dipstick. Works awesome
I had previously dropped the pan, actually installed a pan with a drain plug, and replace the filter. This makes changes so easy with the mity vac.
I've been dropping the pan and changing the filter and refilling with 4 plus quarts every 20k miles. However, the next time I think I will syphon the fluid out through the dipstick tube leaving the pan on. It can be done without a mityvac. Just get the syphon going and let it run.
