Lost Reverse in 2009 F150 4.6l 2wd 4R75E transmission.
I got into some mud towing a trailer. Lost reverse gear. I didn’t hear a loud pop or anything. I believe the transmission warning light came on the dashboard or whatever that wrench symbol means. I have code P0722, transmission output speed sensor, but no check engine light. So I have all gears and it drives fine in overdrive. It works fine in manual 1 and 2 and the engine brakes itself in those gears as well. Is it possible it’s something other than the reverse band or sun cone gear weld? It has the proper fluid level and I changed the fluid/filter about 2 years ago around 70-75k miles. It has around 95k miles now. Thanks for any help
