1999 Rear output seal
Old Aug 12, 2021 | 05:20 PM
Red_317's Avatar
I have a 99 4.2L and I noticed my rear output seal was leaking. I was trying to find the part but noticed there are 2 options one with a long boot and one with a short boot. So my question is, is there a way to know which one I need without tearing it apart? I don't have the owners manual either btw. Thanks for the help yall.
Old Aug 12, 2021 | 09:47 PM
Roadie's Avatar
I presume you are talking about the rear transmission seal? I think I would verify both are available and pull the seal and check it before buying a new one.
Old Aug 12, 2021 | 10:00 PM
Red_317's Avatar
Yea the Rear output Seal on the backend of the transmission where the driveshaft is at. It is leaking heavily so I am pretty sure it is bad. but I have called an verified both are available, I would just rather not buy one unless I know which one I need. but I tried google and it failed me for once and I couldn't find any posts on here. Do I just need to tear it apart to figure it out?
Old Aug 12, 2021 | 11:44 PM
I think so, unless a Ford dealer can research it with your VIN. Just buy both and make sure you can return the one you don't use. They aren't that expensive. When you pull the driveshaft, check the yoke for burrs or damage that could be eating the seal.
Old Aug 13, 2021 | 09:24 AM
Red_317's Avatar
Alright, Thanks for the help yall. I wouldnt have thought to check the yoke. Thanks!
Old Aug 13, 2021 | 10:07 AM
Roadie's Avatar
I think there is a bushing that the yoke spins in that could be worn. Check that also. It could need more than a seal.
