4wd not engaging
Old Aug 27, 2019 | 09:58 AM
jbrowder22's Avatar
4wd not engaging
Ok, so I know this has probably been answered 1,000 times. Today is my first day on site, 😁.
My 06 won’t engage the 4wd. When I turn the selector switch the light will flash one time but never stay on. For a few days, you could hear the motor thump like it wanted to engage, so I tried the mallet trick. It worked one time. Now I’m back to the same issue. I’ve already set in my mind I need to replace the transfer case motor, but before I do, I figured I’d ask if I should be looking in another direction. Thanks!
Old Sep 17, 2019 | 10:50 AM
JackandJanet's Avatar
Bump
Since it worked with the mallet once, sounds to me like the thing's "stuck". Can it be rebuilt?
- Jack
Old Sep 17, 2019 | 01:17 PM
jbrowder22's Avatar
I have no clue. I know that they sell remanufactured ones, So I would assume it’s possible.
Old Sep 18, 2019 | 06:50 AM
Fbird's Avatar
YES they can be rebuilt just not by the "end user" as WE can't get the individual parts
Old Sep 18, 2019 | 09:52 AM
Roadie's Avatar
Maybe not from Ford but I just googled and found this link.]
https://www.carid.com/ford-f-150-transfer-cases/
Old Sep 22, 2019 | 10:53 AM
Fbird's Avatar
refering to the case motor. Yes manufacturers can and will rebuild them but end users will never find the parts.
for the transfer case!!!....yes anybody can rebuild them...parts are easy peezy
Old Sep 26, 2019 | 03:47 PM
jbrowder22's Avatar
Ok.. I’ve changed the transfer case motor, the vacuum solenoid and fluid change.. still no 4wd. I can hear it click but that’s it... the light will flash one time. Then nothin.. any ideas?
Old Sep 26, 2019 | 06:03 PM
jbrowder22's Avatar
My 4wd does in fact work. The light just doesn’t come on for 4-High, it will come in for 4-low, After more research I’ve decided to change out the vacuum reservoir, check valves and the lines themselves. From what I’ve read on other posts here the light will do that if there’s not a full vacuum. Which means there’s a leak or it’s full of water.. stand by while I order parts. 😁
Old Oct 3, 2019 | 03:48 PM
jbrowder22's Avatar
Not happy...
flushed T-case, changed IWE Solenoid, changed vacuum reservoir, changed all the vacuum lines to the actuators. When I crank the truck I get a test light, so I know the 4-hi light works. Put it in 4-hi and no light... put it in 4-low and I get a light. I have 4wd, I just don’t think it’s fully engaging??? Just ordered new actuators.. hoping that fixes the issue.
Old Oct 3, 2019 | 06:12 PM
jbrowder22's Avatar
Time for y’all to laugh.... 😂😂 I went to reading some other threads here, so I went and check the one thing I didn’t check.. fuse #11 was blown. Now my light works as it’s supposed to.. I’m still going to change the actuators, since I’ve already ordered them. So if you have issues with the 4-hi light not working proper... check the fuse. 😂
Old Oct 3, 2019 | 09:42 PM
Roadie's Avatar
Congratulations! Now lets hope the fuse doesn't blow again.
Old Oct 3, 2019 | 10:46 PM
jbrowder22's Avatar
Long as I don’t turn the ac on I should be fine.. #11 runs the compressor and 4wd function. My compressor is bad on the AC.
Old Oct 3, 2019 | 11:33 PM
Unplug the compressor. It will try to run if you use the defroster.
