4R75E same as 4R75W transmissions?
The misfire usually shows up right after it shifts into overdrive under light throttle - around 40 mph or so. If you have more than 60k on the spark plugs it's due. If it still does it you may need one or more coils. A live scanner can detect misfires before they are bad enough to trip a CEL.
If it really is the converter clutch shuddering you can fix it without replacing the torque converter. Do a full fluid change with a good quality MERCON V fluid. That cures about 94% of the vehicles with shudder problems.
I think it is misfire, too.
