P1740 and OD flashing
Old Apr 11, 2018 | 11:52 PM
EdgarH's Avatar
Hey guys so I have a 2001 F150 super crew 4x4 with the 4.6 with the 4r70w transmission that has a code p1740.
Had the code p0740 a few days ago without OD flashing on and off. I replaced the tcc solenoid and it drove fine for a day and now the OD is flashing, shifts hard and has P1740 "inductive signature malfunction"
Did I mess up the harness in there? I wasn't able to remove the harness because one side wouldn't pop off so I just moved it up and out of the way so I could replace the tcc solenoid.
I plan on going back into it to check it out but just wanted to get any suggestions before hand.
thanks
Old Apr 12, 2018 | 12:16 PM
It sounds like the harness.
Old Apr 12, 2018 | 12:49 PM
EdgarH's Avatar
I was thinking the same, I'll pick up a new one and see how it goes.
thanks for the reply !
Old Apr 13, 2018 | 11:37 AM
Mark Kovalsky's Avatar
It's not the harness. The ONLY way that code can set is if the solenoid sticks. The harness can't make the solenoid stick.
Old Apr 13, 2018 | 12:45 PM
EdgarH's Avatar
Is there anything that would make it stick other than just being a faulty part? Because it's brand new but it's a power torque brand
Old Apr 15, 2018 | 08:32 PM
Either a faulty part or contamination in the trans fluid caused the new solenoid to stick.
