Truck stalls in reverse only when warm
I have a 94 f150 5.0 E40D tranny and every time my truck gets warm after driving a while it will stall in reverse. I can usually save it by tapping the gas repeatedly. It does fine in all other gear except reverse in which it does fine when the truck is cold. Ive been trying to figure this out for about a year now ans no one seems to know what's going on. Ive read tons of articles and basically come down to the conclusion that it has to be either line pressure or filter falling out which these trucks are known for. Any help would be great including tests, diagnostics or whatever. Thanks.
A 0-350 PSI pressure gauge would tell the story. There is a test port on the driver's side of the trans, towards the front of the trans, just above the pan. See what the pressure is cold and warm. I'll be the pressure is dipping low when warmed up.
What does that mean if it does dip low when warm? And should it stay generally the same PSI while cold and warm?
