2002 TCC relay location.
My 2002 F-150 2x4 has had the tranny changed in the past. Now has a TCC problem. I removed the tranny pan. The tranny has a relay pack. Is the TCC relay in the relay pack? If not where is the TCC relay?
Denny
Maybe this will make it easer to understand my questions.
Transmission-torque-converter-clutch-solenoid.
Solenoid pack.
Denny
Solenoid pack.
mitymerc,
Thank you for the come back. I have determined my transmission is a E40D.
Is the TCC solenoid in the Solenoid pack or some where by its self?
Truck works fine in reverse but jerks and stalls in forward at first start to move forward.
Denny
Denny
mitymerc,
Denny
Denny
It is 100% impossible for it to be an E4OD.
It's likely the 4R70W, but you'd have to go and read the label on the door, then look up the code, to know for certain.
Here are the possible "TR" codes for the 02 F150:
M — five-speed manual overdrive (Mazda M5R2-C)
U — four-speed automatic (AODE, W/4R70W)
E — four-speed automatic (4R100)
7 — four-speed automatic (4R100), Lightning
