how many quarts go in to pan?
Old Oct 28, 2013 | 08:12 PM
K.R.newbie's Avatar
Question how many quarts go in to pan?
Going to drop trans pan. Along with replace trans filter.
It's a 4r70w in a 2002 f150 with a 5.4. It's got 179,000 miles.
I don't know if or when it was last done.
Old Oct 28, 2013 | 08:47 PM
jaws12's Avatar
....never mind... I'm not sure. I'd say 6 quarts would cover it.
Old Oct 28, 2013 | 10:41 PM
Roadie's Avatar
5 qts will be more than enough
Old Oct 29, 2013 | 01:24 AM
MitchF150's Avatar
I know my E4OD takes 6 qts for a pan drain.. The E4OD/4R100 seems like it has a bigger pan than the 4R70 from pics I've seen...
Anyway, just try to capture as much of the fluid as you can and pour it into qt containers if you happen to have them.. Or a 5 qt jug, etc. then you'll know how much came out.
Good luck!
Mitch
Old Oct 29, 2013 | 12:55 PM
The book says 5 quarts.
With 179k I'd seriously consider doing a complete exchange.
Old Oct 29, 2013 | 03:47 PM
jaws12's Avatar
If you can drop the pan you can flush 16 quarts through it and be 100% better off. Easy job.
Old Nov 9, 2013 | 06:03 PM
K.R.newbie's Avatar
Well it's done. Boy is that a messy job to do. Guess what I found in my pan????? Wait for it.............. yellow plunger!!!!!!!!! So I was right in guessing that it has never been done. Not that there was anything wrong. Bought 5 QTS for it,,, took 4 QTS based on the Haynes manual and the dipstick.
They should sell a shop full of equip when you buy a vehicles as one package deal!!!!!
As I was under my truck I noticed one of the end links on my sway bar was missing the bushings on both ends and it was making noise to boot. drivers side!!!
Old Nov 9, 2013 | 06:43 PM
The plunger just means the pan has never been dropped - or they left it in. It's very possible the fluid has been exchanged with a machine before.
Old Dec 9, 2013 | 07:55 PM
BlueOvalFitter's Avatar
Thumbs up
4 qts. puts the fluid in the center of the cross hatched area on my dipstick.
