week clutch
Old Apr 11, 2013 | 01:12 PM
Spaz88's Avatar
week clutch
I just got a 95 f150. the clutch is week what all could be wrong?
Old Apr 11, 2013 | 01:16 PM
Spaz88's Avatar
The clutch doesnt come all the way up when you let off
Old Apr 11, 2013 | 11:16 PM
jgger's Avatar
Check the fluid, if you're lucky that is all that it is.
Could need to be bled. Or a bad master or slave cylinder.
Good luck.
Old Apr 12, 2013 | 10:24 AM
Spaz88's Avatar
Good luck.
I checked no leaking under the hood or anywhere else
Old Apr 12, 2013 | 10:39 AM
Spaz88's Avatar
Ill check the line when i get off work
Old Apr 12, 2013 | 02:33 PM
Spaz88's Avatar
No air in the line
Old Apr 12, 2013 | 02:39 PM
Spaz88's Avatar
Im going to pick up some hydrolic fluid on the way home after i blead it
Old Apr 12, 2013 | 02:41 PM
Spaz88's Avatar
Ill let you know if no change
