Shuttering from the Transmission
Old Mar 29, 2014 | 10:25 AM
DeltaFX4's Avatar
Excuse me, coils have been replaced, plugs are old...
Old Mar 29, 2014 | 03:31 PM
90k on plugs? It's time.
Old Apr 1, 2014 | 12:42 PM
DeltaFX4's Avatar
Then lll do that first....turning OD off makes it go away... Still think its a possible misfire?
Old Apr 1, 2014 | 01:58 PM
jaws12's Avatar
Originally Posted by glc
Exchange, don't flush. There's a difference.
I did the driveway fluid change where you empty 4 quarts at a time via the cooler return line and then add 4 new quarts until all is done. Is that what you mean by exchange?
Old Apr 1, 2014 | 02:02 PM
Yes, if you did it correctly and got all the old fluid out. Machines use the transmission pump to simultaneously push out the old fluid and draw fresh fluid in.
Old Apr 1, 2014 | 08:45 PM
Mark Kovalsky's Avatar
Yes, that's a typical response when the problem is misfire.
