Knocking Sound
Old Apr 1, 2013 | 05:51 PM
Bryan Lalik's Avatar
Knocking Sound
I'm driving an '02 4.2L V6 F150, its a manual. There is a consistent knocking sound coming from what I suspect is the tranny. From the minute I start it up, the sound begins. It continues while I drive, and it picks up with frequency as I speed up. This happens in all gears. Even while I am rolling down a hill in neutral, the sound continues. Does anyone have any idea what might be causing this noise?
Old Apr 14, 2013 | 09:57 PM
philcamlin's Avatar
Could you post a sound of it? There are many sounds a trans could be making. Just to check... kids used to put zip ties on the drive shaft and it would hit the bottom of the truck when you drive lol. I've seen it once before.
Phil
Old Apr 15, 2013 | 10:08 AM
Does the knocking EVER stop? What about sitting still in neutral? What about with the clutch released, both moving and sitting still?
Old Apr 16, 2013 | 10:28 AM
Spaz88's Avatar
Are you sure its not coming from the engine? If you have a bent rod it will make a knocking sound that is constant
Old Apr 16, 2013 | 10:31 AM
Spaz88's Avatar
Is it a auto or standard?
Old Apr 16, 2013 | 10:35 AM
This:
Old Apr 22, 2013 | 03:36 AM
Spaz88's Avatar
It could have broken teeth on the fly wheel
Old Apr 22, 2013 | 01:00 PM
I doubt that - if the flywheel had broken teeth you would have starter issues.
One and only one post made 3 weeks ago, no reply. I think we are wasting our time.
