E4OD to 4R100?!?!?!
Old Jan 7, 2013 | 12:15 AM
93f150302's Avatar
E4OD to 4R100?!?!?!
Ok so I've been doing some reading on the E4OD and 4R100. What I've seen is they are they are the same but the 4R100 is stronger. I have a 93 F150 5.0 and for the cost of an E4OD I can get a 4R100 I want to swap in the 4r100. WILL THE 4R100 JUST GO IN WHAT DO I NEED TO DO THE SWAP?
Old Jan 7, 2013 | 06:18 PM
Mark Kovalsky's Avatar
I don't think this will work in your truck. The 4R100 was never made with the small block bolt pattern that a 5.0L engine has. Bellhousings are not removeable on the E4OD or 4R100, so you can't swap them. I suppose someone could make an adapter, but that's not going to be cheap. Also, an adapter will move the trans back so you'll need to move the rear crossmember and shorten the driveshaft. If it's a 4x4 you'll also need to lengthen the front driveshaft.
Old Jan 8, 2013 | 02:07 AM
Martim's Avatar
Originally Posted by 93f150302
ok so i've been doing some reading on the e4od and 4r100. What i've seen is they are they are the same but the 4r100 is stronger. I have a 93 f150 5.0 and for the cost of an e4od i can get a 4r100 i want to swap in the 4r100. Will the 4r100 just go in what do i need to do the swap?
4r100 is not such a good stuff as you are thinking of it i would say that you must prefer the other one. Its useless to invest your money in 4r100
Old Jan 8, 2013 | 10:09 AM
93f150302's Avatar
Ok thanks! I think ill stick to the E4OD and beef it up a bit
