Shifter interlock solenoid, Center shifter prob.
Old Aug 15, 2012 | 12:53 PM
wheelentime's Avatar
so I have a 04 FX4, the Shifter interlock solenoid is shot, I have to push the little white button every time now to shift it out of park. does any one know if the Center Shifter has a different solenoid then the column shifter and if so, can i get a part number and a place to get it. as you know the FX4 is the Center shift.
Old Aug 15, 2012 | 01:30 PM
Yes the center console has a different solenoid, and its available through ford, I want to say its 80 ballpark of the solenoid and harness.
Takes about 30 minutes or less to install it
Old Aug 15, 2012 | 01:37 PM
Im just trying to get a part number because Im trying to avoid another ford part, if it didnt last that long and its not ment to wear out. then its not a part i want to get again from ford.
Old Aug 15, 2012 | 07:17 PM
sam1947's Avatar
The only place to get that solenoid I believe will be from Ford. Doesn't matter where a part comes from, all parts are subject to breakage and wear out. Part # 7L3Z-7E096-A : This an 07 part #, however I believe they are all the same.
http://www.ebay.com/itm/BRAND-NEW-FO...-/230693200306
Old Aug 20, 2012 | 04:42 PM
thank you for the number, and Im not so sure about that, Iv had parts where Iv bought from one company and it go out 2 or 3 times then bought from another company and it last the rest of the life of the truck. but I guess thats all opinion. thanks again.
Old Aug 20, 2012 | 07:19 PM
sam1947's Avatar
Sounds like a situation of who may be building the part at the time, different contractors-same part #. Just a guess...
