4.2 Tranny Swap
Old Jul 14, 2012 | 12:46 AM
ODub93's Avatar
4.2 Tranny Swap
I am new to the forum and have a quick question. Any help is greatly appreciated. I have a 99 f1 ext cab 2wd with the 4r70w trAnny. The other night while driving home my tailshaft exploded causing my driveshaft to snap in half. I decided I was gonna throw a 5 speed in it. I found a few online but they wanted 300 well I found one at the local pull a part but it's out of a 97 4wd. Will it work I know that I need to change some stuff but will it bolt up everything looked pretty much the same but my oil pan looks quite a bit different than the 97. Is the bell housing the same? Thanks guys I appreciate it
Old Jul 14, 2012 | 02:32 AM
It has to be out of a 4.2 or it will not bolt up, and can't be adapted. The 4.6 has a different bellhousing pattern. You will need a flywheel, bellhousing, clutch assembly, etc. and if it's a 4wd trans you will have to tear it down and change the whole tailshaft. You may also need a PCM out of a 99 manual trans truck.
Old Jul 14, 2012 | 11:21 AM
ODub93's Avatar
Yeah it it a 4.2 but the oil pan looked quite a bit different thank you I appreciate it and will the tail shaft on the transfer case bolt up to the tranny?
Old Jul 14, 2012 | 11:52 AM
A 4wd trans will not bolt up to a 2wd driveshaft. A 2wd trans will not bolt up to a transfer case. That's why I said the whole tailshaft needs to be changed.
Old Jul 15, 2012 | 02:19 AM
ODub93's Avatar
Okay thanks bud I appreciate it
Old Jul 19, 2012 | 10:14 AM
ODub93's Avatar
Will I need to change my ECM?
Old Jul 19, 2012 | 12:23 PM
I think so. The ECM controls the 4R70, there is no control with a manual.
Old Jul 19, 2012 | 01:21 PM
ODub93's Avatar
Okay thanks
Old Jul 22, 2012 | 06:28 PM
ODub93's Avatar
Is there any ways way to remove the brake pedal assembly? I took all the bolts out and the pedal but it seems like there is no way to get it out of there without either ripping out the whole dash or removing the brake booster
Old Jul 22, 2012 | 11:29 PM
ODub93's Avatar
. What part of this do I have to cut out to mount the shifter
Old Jul 22, 2012 | 11:54 PM
ODub93's Avatar
<a href="http://s1110.photobucket.com/albums/h442/owen_ambrose/?action=view&current=9ea363ce.jpg" target="_blank"><img src="http://i1110.photobucket.com/albums/h442/owen_ambrose/9ea363ce.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a> what part do I cut out?
Old Jul 22, 2012 | 11:56 PM
ODub93's Avatar
Old Jan 2, 2023 | 09:31 PM
Byron1982's Avatar
2002 to 2001 f150 4.2 transmission swap
2002 and 2001 f150 4.2 transmissions are same but shift sensor plug’s different how to get to work
