Transmission Help
Old Aug 8, 2001 | 10:50 AM
86f150's Avatar
Transmission Help
I just got an 1986 F-150 302 V8 with a 4 speed automatic transmission that has overdrive. I want to change the fluid in the transmission but I don't know what type it uses. Does anyone know or could tell me where I could find out? The truck has no owner's manual. Also, does the tranny have a filter or anything that would have to be changed out? Any help would be appreciated. Thanks.
Old Aug 8, 2001 | 11:08 AM
Ranchero1968's Avatar
Trans ???
86f150,
There are a few things you can do.
1st: Check the Tranny dipstick. It will have the Ford Spec # for the Trans fluid stamped on it.
2nd: Get a Haynes or Chiltons service manual at your local parts store.
3rd: Match the Ford Spec #, with trans fluid at your local parts store.
Just a note: In order to get all the trans fluid from your Torque convertor, you need to either drain the convertor, or take it to a reputable Oil Change place, and have them flush and service the system.
This will One, clean/condition the trans and seals.
Two, flush out all of the old fluid.
Three, clean the trans screen(filter).
I have had it done in the past, for time saved, and not busting up my knuckles. I think I paid $70 to have it done. It should take about 45 minutes to have it done.
Best Of Luck...
R1968
