What is the best fluid and filter?
Old May 17, 2012 | 09:08 PM
  #31
sam1947's Avatar
Done with you...............you seem to think that whatever you say is gospel..guess what...it isn't. Been proven many times here.
Old May 17, 2012 | 09:22 PM
  #32
Takeda's Avatar
read and weep:
http://wiki.answers.com/Q/Compare_Me..._To_Dextron_VI
https://www.f150online.com/forums/tr...mercon-vi.html
Old May 18, 2012 | 01:44 AM
  #33
AndersonS's Avatar
Old May 18, 2012 | 10:24 AM
  #34
Originally Posted by Takeda
WRONG! No such thing as Mercon VI, there is however, a Dexron VI!
You are correct. There's Mercon V, Mercon SP, Mercon LV, and Mercon C. There used to be plain old Mercon.
Mercon V is used in all 4 speed truck automatics through 2008.
Mercon SP is used in the 5R110.
Mercon LV is used in the truck 2009+ 4 speed and all 6 speeds.
Mercon C is used in the car CVT.
Now, just to aggravate you some more, Amsoil ATF may be used in Mercon V applications. Amsoil ATL may be used in Mercon SP/LV applications.
Old May 18, 2012 | 11:22 AM
  #35
MossyOak3006's Avatar
So if I got Amsoil, I would need Amsoil ATF for my 2006 4 speed? That dealer is only 20 minutes from me. Is it worth the extra cost to get Amsoil?
Old May 18, 2012 | 11:56 AM
  #36
sam1947's Avatar
The choice is up to you. I have it in mine and it works great..smooth shifts and runs a little cooler than Mercon V. Check out jbrew's posts on the subject. It's very well worth the extra cost IMO.
Old May 18, 2012 | 01:59 PM
  #37
I think I'll go for it then
Old May 18, 2012 | 06:12 PM
  #38
Remember - for a complete exchange with a machine you will need about 14 quarts. It is NOT worth using Amsoil - and actually NOT recommended - if all you are going to do is drop the pan. You should not mix fluids.
Old May 18, 2012 | 07:27 PM
  #39
sam1947's Avatar
I agree with glc here. If you have deep pockets for a complete exchange..I would go with Amsoil, however, if you are only going with a pan drop, I wouldn't mix the two (even if Amsoil states there would be no compatibality issues). Get a quote for Amsoil and Mercon V (14-15 qts), then decide.
Old May 18, 2012 | 08:20 PM
  #40
Amsoil is $11.50 a quart, here's the prices on Mercon V at Autozone:
Coastal - $4.99
Valvoline/Castrol - $5.99
Mobil 1 - $9.99
Old May 19, 2012 | 08:02 AM
  #41
EsJayEs's Avatar
Originally Posted by AndersonS
Good call.
Short answer is to check the bottle. If it says "Meets specification" for Mercon V, you're good. If it says "Recommended for use..." for Mercon V, it doesn't meet spec. That's a manufacturer's clever way of saying "This doesn't meet spec, but you should buy it anyways".
It's just that simple. Valvoline and Castrol are easy to find and meet spec. Amsoil and Mobil1 do not.
Before people start getting into another futile thread, it's been done recently.
https://www.f150online.com/forums/tr...fluid-use.html
Old May 19, 2012 | 08:43 AM
  #42
Excuse me..........
Mobil 1 Synthetic ATF meets or exceeds the requirements of:
JASO 1-A
Ford Mercon V
Old May 19, 2012 | 08:49 AM
  #43
EsJayEs's Avatar
Excuse me..........
You're absolutely right. I was in sleep mode. I meant to say Royal Purple.
Must get coffee...
Old May 19, 2012 | 04:13 PM
  #44
AndersonS's Avatar
Uh-oh...
