shifting problem
Old May 3, 2012 | 06:48 AM
thundafoot's Avatar
shifting problem
I have a V6 4.2 with AODE and the problem is it shifts into first to second fine but won't shift into third until I hit 45 mph then it goes to third nd then overdrive only when the light isn't flashing. When the light is flashing it will only go to overdrive at 45 mph is this a selonoid problem or is my trans gone.
Old May 3, 2012 | 11:07 AM
You won't know till you get the DTC codes read out - when the OD light flashes it's setting codes. Autozone, etc. scanners can't read them, you need a higher end scanner. Take it to a dealer or transmission shop.
By the way, you don't have an AODE, you probably have a 4R70W. What year is the truck?
Old May 5, 2012 | 12:48 PM
thundafoot's Avatar
It is a 2000 F150
Old May 5, 2012 | 01:39 PM
Mark Kovalsky's Avatar
The last year the AODE was manufactured was 1995, and that was only in the Mustang. You have a 4R70W transmission.
Old May 7, 2012 | 07:10 AM
thundafoot's Avatar
Ok ty for the info. Will let u kn what the codes r. If its an easy fix I'm all about that but don't really want to have to buy a new trans
Old May 13, 2012 | 12:07 AM
papa tiger's Avatar
Removing the trany valve may show broken metal piece causing the problems.
Old May 13, 2012 | 07:45 AM
What is a trany valve?
