trans blowing fuses!!
Was running fine after install. Then one day right at start up got trams fault, found the fuse , changed it. Pop it blew. Don't see we're any wires ( except o2 sensors) are anywhere near headers.
You said you just installed headers and now the fuse blows. You didn't say it was running fine for some period of time before the symptom occurred.. Clarity in describing symptoms is pretty important. Without it, you won't get accurate feedback.
Trace the wires anyway. You have a short-to-ground in whatever circuit that fuse is protecting.
