Which Tranny Fluid? Help!
Old Jul 30, 2001 | 06:37 PM
5150PhD's Avatar
Question Which Tranny Fluid? Help!
I'm going to be installing my transgo shift kit and wanted to get some feedback on the type of fluid I should go with. My specs say to use Mercon V. What about synthetic? Any comments guys?
Thanks in advance!!!
Matt
Old Jul 31, 2001 | 04:39 PM
jstang's Avatar
I can tell you I used synthetic in my Mustangs AOD, I could only find Castrol at the time, after a while, I thought the tranny was hurt, and just for a shot in the dark, I desided to try changing the fluid.
I drained the converter and all, and replaced it with Mobil One, night and day difference, get Mobil one if you go syntheic.
Old Aug 1, 2001 | 02:18 AM
Lok N Load's Avatar
When I did my Transgo kit a few weeks ago, I drained the torque convertor and filled everything back up with Amsoil synthetic. It's a bit expensive at $8.00/qt for 14 quarts, but I think it's well worth it.
Lok
Old Aug 1, 2001 | 11:36 AM
5150PhD's Avatar
Talking
Thanks for the info guys.
Old Aug 8, 2001 | 10:46 PM
ruger-dfw's Avatar
Re: Which Tranny Fluid? Help!
AMSOIL Synthetic Automatic Transmission Fluid exceeds the performance requirements for domestic and foreign automatic transmission fluid applications. AMSOIL ATF provides automatic transmissions, power steering units and hydraulic equipment with excellent lubricating protection and better performance over a wider temperature range than do conventional petroleum fluids.
Meets or exceeds the following performance specifications:
GM Dexron II, Dexron III
Ford Mercon, Mercon V
Chrysler ATF+, ATF+2, ATF+3, ATF+4
Allison C-3 & C-4
Caterpillar Powershift Transmission TO-2 & TO-3
Voith Commercial Transmissions
GM Strasbourg (European Imports) and Opel
Improves fuel efficiency, reduces transmission temperatures and increases transmission life. Provides unsurpassed thermal stability and up to five times the service life of conventional ATFs. Delivers maximum protection for towing and other severe-duty applications.
AMSOIL ATF provides smooth shifting and long, trouble-free transmission life. In addition, the anti-wear additive package makes AMSOIL ATF an excellent lubricant in other hydraulic systems. In tests designed to measure wear characteristics under severe service and high pressure operating conditions, AMSOIL ATF far exceeds the requirements of hydraulic equipment manufacturers.
Hop this helps. Let me know if I can help.
Old Aug 9, 2001 | 11:03 AM
5150PhD's Avatar
Thanks Ruger!
At this point I'm going to go with the Mercon that Ford recommends and see what happens with the transgo install (goes in this sunday ). More than likely I'll start converting the engine oil and tranny fluid over to synthetic. When I do, I'll look you up again for some questions.
