trans temp
Old Feb 15, 2012 | 12:07 AM
FF301's Avatar
trans temp
what is the "normal" temp range for these transmissions
i have f150 2005 4x4 5.4l eng mostley stock
with an avarage daily temp around 35* my new trans temp gauge sometimes shows 100 and sometimes up to 150, also do they regulate the temp just like the eng or not
Old Feb 15, 2012 | 12:54 AM
ak_cowboy's Avatar
Mine with a transmission cooler gets up to 150* for regular daily driving. Right now it gets up to maybe 130* since it's so cold out. You can get it up to 200* without worrying about it too much
Old Feb 15, 2012 | 09:12 AM
fairlaner's Avatar
Where did you put the temp sensor? A sensor in the output line (line to the first cooler) will show higher peak temps and more varied temps than a sensor in the test port.
I put my sensor in the output line and see temps from 100* gently cruising down the highway, to 180* + on a curvey, hilly road. I have yet to really stress the trans since I installed my gauge, but I suspect I'll see some pretty high temps for the short term when I do.
Old Feb 15, 2012 | 07:30 PM
MTM Ford's Avatar
The highest I've seen mine go is 155*. That was on a back road going 40-45mph with OD off. It's usually between 148 and 150 on the highway. I haven't seen it go above 150 other than that one time.
Old Feb 15, 2012 | 07:35 PM
camopaint0707's Avatar
100 or so for my f150
Old Feb 16, 2012 | 12:28 AM
FF301's Avatar
i installed it in the line from the trans to the radiator. from what i read on here, this is output from tranny and the line from the aux cooler to the tranny is the return - do i have this right ???
i am going to take this apart tommorrow because my "t" fitting is leaking around sensor threads (very small drip) just going to re-apply thread sealer.
Old Feb 16, 2012 | 08:13 AM
My sensor for my trans temp gauge is in the actual transmission. Not a line.
Old Feb 17, 2012 | 07:24 PM
Mark Kovalsky's Avatar
Yes you do.
