Transmission Swap
Transmission Swap
Hi. I'm considering getting a 2001 Lariat SuperCrew 2wd 5.4. I would like to know what I would need to swap in a manual transmission. I've heard that the manual trans will bolt up to the 5.4. Would I have to purcase a computer for a manual 5.4 from a superduty, or is there a company that can burn a chip to remove the shift points from the auto computer? Would the pedal mounts be under the dash already? Would it be hard to swap the gauge panel out from a F150 with a 5 speed? Would I have to change wiring harnesses? Thanks alot....Matt
