want a six speed manual
The 6 speed ZF out of the Super Duty (which is a difficult conversion) doesn't even have a double overdrive - 1st gear is a granny and the rest of it is just like your 5 speed. Your only solution is quite expensive - a Gear Vendors overdrive.
If you want to reduce highway RPM, why not gear it to something more reasonable? If 4.56 yields excessive RPM, obviously it wasn't the right choice.
