2nd gear problem?
Old Dec 27, 2011 | 08:26 PM
04f150inmn's Avatar
2nd gear problem?
Have a 2004 F150. My tranny shifts fine and dosn't seem to slip at all but I have noticed that if I am in drive and I manualy shift into 2nd it seems to loose power and as soon as I shift it back I can feel the power again. If I start out in second gear it seems as if it has no power? I can floor it from a dead stop (in D) and it shifts firn threw all the gears. I can't figure out what would be causing the tranny to do this. I have a warr. and am wondering if this is something that I should be worried about or is it just me?
Old Feb 19, 2012 | 11:13 AM
EvanT08's Avatar
I have the exact same issue and have no idea why.
Old Feb 19, 2012 | 07:14 PM
Mark Kovalsky's Avatar
When you start with the shifter in 2 the trans starts in 2nd gear, not 1st gear. That will make it seem like it is down on power. It's normal and working as designed.
Old Feb 20, 2012 | 08:27 AM
04f150inmn's Avatar
it is bad if I go from drive to 2nd (say at 20mph) it dosn't feel like it is holding rpms, not like its slipping but seems to be loosing power?
Old Feb 20, 2012 | 09:02 AM
EvanT08's Avatar
That may be Mark, but I'm not convinced there isn't a problem. I can floor it in 2nd and have no power. I have power through 2nd gear if the shifter isn't in 2nd. I can also maintain steady throttle in 2nd with little power and shift up to 3rd and have instant power and no noticeable gear shift.
Old Feb 27, 2012 | 10:25 AM
04f150inmn's Avatar
that is how mine is as well.
