no reverse
Old Sep 24, 2011 | 03:27 AM
dogface66's Avatar
Angry no reverse
i have an 07 f-150 4.6
i ve lost reverse just like that
105,000 kms
have not tried yet but i can only assume i ll get screwed on the warrenty being 5000 over
no warning nothing just gone,
forward is ok
could it be as simple as an oil change?
oil is good by the way
any ideas clues or help much appreiciated
thank you
dogface66
Old Sep 24, 2011 | 03:42 AM
Need4racin's Avatar
well you're suppose to change the atf every 30k miles. Does the fluid have metal flakes in it or is it black? Is it pink milk shake looking (coolant leaking into atf cooler)?
If the fluid looks good, it's probably a sensor. Pull codes.
Old Sep 24, 2011 | 06:25 AM
Mark Kovalsky's Avatar
It's not a sensor. There is no sensor that could prevent it from engaging reverse. It has to be a mechanical failure.
Old Sep 24, 2011 | 07:06 PM
Flash69's Avatar
Not to be the bearer of bad news, but it's usually not a simple fix when you lose reverse.
My wife's 2004 Expedition had something similar, at 114,000 miles. No reverse but she also lost top gear. I dropped the pan to check the fluid and it was brownish (meaning it had particles in it). The magnet also had a lot of shavings in it.
I ended up buying a used trans for $600.00 and replaced the transmission. I still have her old one in the garage and I plan to take it apart to rebuild it. Waiting on winter time so it's not 100+ outside every day.
NOTE: I am in NO way a transmission expert. Only offering up information.
Old Sep 25, 2011 | 03:06 AM
dogface66's Avatar
no the oil seem ok full in park and warm.
and a clean red
i have nothing but problems with ford
one starter -one power steering-onedifferential at 60,000-
cat converters...,
at least that was all under waarrenty.
i dout they have any honor to fix this problem
thankx though for your input
Old Sep 25, 2011 | 03:12 AM
dogface66's Avatar
thank you for the inputi suspect you guys are right in assuming the worst,
i havent got into it yet,but i dont think i could be so lucky as dirty oil.
i think they build them tofail just after warrenty,
this isnt the first time,
i had a 19905 speed manual new and reverse mysteriously failed then just after warrenty expired.
thankx for your time
Old Sep 25, 2011 | 08:14 AM
UCF-150's Avatar
Most likely your reverse band failed. Unfortunately to replace the reverse band you have to take the trans most of the way apart.
Old Sep 25, 2011 | 12:06 PM
UCF-150's Avatar
Thinking about it some more, it could also be something with the reverse servo pin. You really won't know until you get it apart though.
Old Sep 26, 2011 | 01:10 PM
01 gt f150's Avatar
This may help.
Unfortunately this would have to be a mechanical problem. There is nothing electrical about reverse gear in the AODE or 4R70W transmissions. You could have a bad Low/Reverse Band, or a bad Reverse clutch pack.
01 gt f150's Avatar
http://www.becontrols.com/ourfaqs/ao...1.htm#02187244
Old Sep 26, 2011 | 10:27 PM
Alexcngford's Avatar
Originally Posted by 01 gt f150
This may help.
I bet its going to be a Reverse clutch. The Reverse band is pretty beefy in the truck transmissions.
That being said you probably need to have a professional look at it.
Old Sep 27, 2011 | 08:12 PM
PickledPolak's Avatar
Does the engine brake in manual low?? If not, L/R band is damaged.
