transmission question
Old Sep 16, 2011 | 01:32 AM
K.R.newbie's Avatar
Question transmission question
ok have a 2002 f150, it has a 5.4, not sure what trans is in it.
I was wondering is there a way to get it shift a little more firmer then it does right now.
Is there like a shift kit for tansmissions still, that increases the pressure that it takes to shift, for the valve body. Think like spring changing????
Or is it a computer tunning thing to make trans shift firmer??
thanks
marc
Old Sep 16, 2011 | 05:07 PM
Mark Kovalsky's Avatar
You can do it either way on your trans.
Old Sep 16, 2011 | 05:34 PM
Do it with a programmer, because that can also modify the engine. CUSTOM tunes would be best.
Old Sep 18, 2011 | 05:11 PM
K.R.newbie's Avatar
glc thats change the transmission with a programmer , so if i want to i can change the engine too???
Old Sep 19, 2011 | 12:20 PM
The transmission and engine are both controlled by the PCM, so a programmer with custom tunes will adjust both.
