M5OD questions
M5OD questions
Tonight I had to park on a really steep hill. In order to get to the spot, I had to back in. It was making a sound like the tires were spinning and I could smell the clutch burning. I don't think the tires actually spun because it was dry and the tires have great tread. Should I get it checked out while I'm still under warranty, or is this common of this weak transmission?
Don't really know a whole lot about the manual transmissions and what (if any) changes have been made to the M5OD. When I had a 92 F150 with a M5OD and 3:08 gears, I'd back up a hill in my driveway and always smell the clutch after I got parked from backing up that hill. It is a fairly steep hill and reverse seemed like it was geared to run down the highway 55-60 mph
You might be ok but if you have any doubt I'd take it in while you're still under warranty.
If you were slipping the clutch trying to back up a hill, it's gonna stink and make noises. Any clutch is going to do that.
Again, it's not a transmission issue, it's a clutch issue, and it's not warranty, that's considered abuse.
Reverse is 3.91:1 and first is 3.90:1. You could call them the same and I would not call you a lier. The clutches from the factory tend to slip when under stress. I run a Kevlar clutch with a stock specification after market pressure plate and it seems to slip a lot less than the factory set up.
