please help with trans problem
Old Apr 24, 2011 | 04:09 PM
mad4002's Avatar
i have a 04 heritage i broke the stock trans case and replaced it with a trans out of a 99 or 00 i am getting a p0720 and p0722 code and would like to know how to fix it ive replaced the sensor but it didnt change anything
when the o/d light is flashing (for the first minute or so of driving) it shifts threw all gears i just doesnt shift at the right time
when the o/d light stops flashing it goes into a limp mode i guess where it wont shift out or 2nd till 70mph and then goes straight to o/d skipping 3rd
Old Apr 24, 2011 | 07:38 PM
mad4002's Avatar
anyone????
Old Apr 25, 2011 | 10:22 PM
mad4002's Avatar
come on over a hundred views and nobody has something to say
Old Apr 25, 2011 | 10:31 PM
Mark Kovalsky's Avatar
I don't remember enough about those differences to be sure, but I'll tell you what I think I remember.
I don't think the '00 trans had a turbine speed sensor. That would set a P0722 and not let the trans shift right. I seem to remember, but once again not sure, that the output speed sensor changed between '00 and '04. I think the '04 has more pulses per revolution. That means the PCM can't understand what it is seeing from the output speed sensor, so it calls it bad, stores a code, flashes the OD light, and goes to limp mode.
The short answer to all of this is that I don't think there is a way to make an older transmission work in a '04 truck. While it physically bolts in it won't ever work right.
You could modify the older trans, but it is going to take a lot of new rotating parts and a new case.
Old Apr 26, 2011 | 06:42 PM
mad4002's Avatar
is there maybe a way to program the truck to see what is wants????
Old Apr 26, 2011 | 09:21 PM
It's probably possible. I'm sure it would cost a lot less to buy a new transmission and have it installed than to write new software that can read what you have.
