edge programmer settings help plz
Old Jan 23, 2011 | 06:10 PM
mote88's Avatar
I think this is the right place to post this...I have an 2005 f150 4x4 on 37s with 4.56 gears with the edge. I have it set on the extreme or performed mode and have the gears progrmed in to...wat else do I need to program in it? Like the shift points or anything? Thx for the help guys
Old Jan 23, 2011 | 06:15 PM
b2therad's Avatar
Nothing, if you are running the level 3 setting all you need to do is run premium (91 octane or higher) gasoline. The only time you need to worry about custom settings is when you write a custom program on it.
shotgunz's Avatar
http://forum.gopowerhungry.com/upgrade-your-evo/
